lenkradnabe für MKIV | Forum
eXplorer Driver
Jul 24 '06
hallo, hat hier im forum einer ein momo lenkrad oder so was ändliches in seiner MKIV??
was für lenkradnaben passen da? gibs da überhaupt wass?
wenn es etwas gibt, wo bekomm ich das?
gruss und danke im voraus
Jul 24 '06
eXplorer Driver
Jul 24 '06
danke für dir schnelle und positive antwort.
Jul 24 '06
Kannst auch bei Sparco direkt ordern: Sparco , Online-Shop
und Sandtler vertreibt die Sachen auch: Sandtler
MikzuIV Driver
Sep 8 '06
Does this sparco "lenkradnabe" also fit in Luisi steering wheels? ( 6 holes...74,5mm between opposite screw holes)
I found a brand new luisi wheel LIKE THIS in the recycling center :grinning:
And does the lenkradnabe for MR2 (W2) fit Supra?
Danke.
Sep 8 '06
Danke.
yes!
If you order a MKIV "Lenkradnabe" form any US dealer you´ll get a MR2 one.
But unfortunately it doesn´t fit 100%!!
It holds the steering wheel as it should, but you´ll loose the "sidemarker return".....so you need to stop the sidemarker flashing yourself...........the lttle holes in the "LAnkradname" don´t fit.
I tried to find a perfect one, but it seems that there´s no "Lenkradnabe" aspecialy for the SUPRA, that maintains the "flashlight return".
MikzuIV Driver
Sep 8 '06
Ok. many thanks.
The blinker returning won't bother me much cause already now it doesn't return, it's broken :grinning:
I found an original luisi "Lenkradnabe" made for mr2 w2, and some others, so I will fit this one then.
:stuck_out_tongue:
Sep 8 '06
DOCH, there IS a flashlight return able "lenkradnabe", i have a momo corse and my "nabe" looks very similar to the sparco ones, and the flashlight returns itself :blush:
und jetzt nochmal auf deutsch...nö :grinning:
Sep 9 '06
Wong...für Sparco Lenkräder gibt´s das nicht....leider...
MikzuIV Driver
Sep 26 '06
Good news.
I had my Luisi "nabe" and it fitted 100% even the blinker returning works.
This nabe has 2 different hole sets, so maybe it will fit other steering wheels than luisi, too.
Only problem is the horn, I had to place a button near the wheel, but maybe my kit misses something for the horn as it's a used one.
It's the same (art Nr: C7019) nabe as for the: W2 MR2 and 4runner,
The new price is 35€. not bad.
eXplorer Driver
Sep 27 '06
ich habe eine nabe gefunden... vom toyota yaris die airbag nabe von momo...:flushed:) sparco konnte nicht liefern..
Provotekk
Nov 18 '07
Ich schreib´s einfach hier nochmal:
Wir haben die MOMO-Naben für die MR2 W2 und Supra auf Lager - ist die gleiche.
[EMAIL]info@provotekk.de[/EMAIL]
Suprapepe Driver
Nov 19 '07
Wolte mir auch ein anderes Lenkrad einbauen lassen!!
Anderes Lenkrad ( ohne Airbäg ) und andere Narbe!!
Kann man ein Lenkrad ohne Airbäg eintragen lassen????
Provotekk
Nov 19 '07
Ja![/B]
Dez 5 '07
ja, aber nur bei autos deren erstzulassung vor 98 ist! soweit mein stand...
für diese fahrzeuge, gibts dann auch rückrüstadapter von raid mit abe, aber leider nicht für exoten wie unsere lady...
sollte aber trotzdem kein problem werden...
oder auf nen raid spilberpfeil umbauen mit airbag
