    Tripod shifter frame solid mount kit to suit Supra ... | Forum
    Zur Anzeige aus unserer Facebook Gruppe
    Tripod shifter frame solid mount kit to suit Supra Mk4 JZA80
    £55 - Amersham, Buckinghamshire
    If your shifter lever is very loose even when in gear, your shifter frame rubber bushes may be worn out.
    This stainless steel bush kit will solidly mount your tripod shifter frame to your gearbox, making your shifts better than new!
    Bush kit replaces the worn out factory bushes shown in photo 2
    (2 pair x lower and 1 pair x upper)
    CNC machined from billet stainless steel for extremely long life.
    Each kit comes with all parts shown in photo 1
    Kit includes installation instructions.
    Fitment.
    All Toyota Supra Mk4 JZA80 6 speed V160 or V161 trans
    Some Toyota Supra Mk4 JZA80 5 speed W58 and R154.
    If you have a 5 speed it is recommended to do the following check before purchase, as some 5 speeds use a direct mount shifter rather than the remote shifter tripod frame which this kit suits.
    Check the shape of you shifter lever under the gear lever boot/gaitor. If your shifter lever has bends in it this kit will not fit (direct mount shifter), if the shifter lever is straight this kit will fit (Tripod mount shifter).
    Alternatively check from under the car, if your shifter is mounted to a frame off the back of the gearbox our kit will fit.
    Will need 10 confirmed names to do at £55 delivered to mainland Uk.
    More than 10 orders can be delivered for £50-
