    Toyota supra PHR race alternator 250 amp £250 - T ... | Forum
    Zur Anzeige aus unserer Facebook Gruppe
    £250 - TQ14 9
    Stock auto is 100 amp. Stock manual is 90 amp.
    Using the 2.9 inch pulley and ATI crank damper, the 240 amp version will make 70 amps at 800 engine RPM. Bumping idle speed to 1000 RPM will increase output to 125 amps. It will produce 240 amps at 2800 RPM. This setup is recommended for high electrical demand cars. and is capable of short burst (not maintained) up to 9000 RPM.
    It will also produce 61 amps at 800 engine RPM using stock crank damper. Bumping idle speed to 1150 RPM will increase output to 120 amps. It will produce 240amps at 3200 RPM. It is not recommended to rev stock crank damper above 7000 RPM. Located teignmouth south Devon. Stuart 07788774991
