    Biete : Radiator Panel | Forum
    Position: Forum » Marktplatz » Angebote
    Nov 1 '07
    Powerhouse Racing Front Radiator Panel for 1993-98 Supra - Polished
    Part # PHR Shield MK4 Pol
    This panel will fit turbo, non-turbo, factory intercooler as well as front mounted intercooler setups. It is a bolt-on part that takes less than 15 minutes to install by the average do-it-yourselfer. This custom panel was hand-designed by Powerhouse Racing while the industrial grade aluminum is fabricated using laser cutting technology. Not only does this panel create a visual impact, it also plays a vital role in the cooling system.
    When front mount intercoolers are installed in Supras, the stock front radiator shroud needs to be removed. The stock shroud is designed to direct the airflow through the radiator, preventing the air from going around. With the stock shroud removed, there is a reduction in cooling efficiency, especially at higher speeds where the fans cannot provide the airflow, since they are not on, robbing your car of potential horsepower. At low speeds the front shroud also allows the fans to operate efficiently as well. By putting an intercooler in front of the radiator, you not only divert the airflow but also heat up the air that manages to make it to the radiator. This Front Radiator Panel prevents the air from rising up over the radiator and loosing crucial horsepower.
    For you wrenchers, it makes a great place to lay your tools and miscellenous parts while you're working on your car! It is made out of industrial grade aluminum for lighter weight and better heat insulation.
    Neu !!!
    Preis 110 Euro
    Nov 2 '07
    Hi Tomi,
    hast PN !!
    Gruß, Stefan
    Nov 2 '07
    ist das auch mit einem CNC-Gutachten ausgeliefert?!!!
    (Insiderjoke) :grinning:Gregor
    Nov 2 '07
    Original geschrieben von: Stefan-MA70
    Hi Tomi,
    hast PN !!
    Gruß, Stefan
    du auch !
    TOMI
    Nov 2 '07
    Original geschrieben von: McGregory
    GREG. ! JETZT REICHTS !!! :grinning::grinning::grinning:
    CNC Gutachten mache ich mit Microsoft Office. Nummer ist kein Problem, schlage ich auch selbst drauf ! So. Zufrieden ? :wink::grinning:
    Nov 7 '07
    VERKAUFT !!!
    Lg
    TOMI
    Nov 7 '07
    Mit oder ohne Microsoft-Office-CNC-Gutachten? :grinning:
    Nov 7 '07
    :grinning::grinning::grinning:rolffffffffffffffffffff :grinning::grinning::grinning:
    Nov 8 '07
    genug gelacht...
    jetzt ist Schluss! :grinning:
