Neue Tuning Teile für Single Turbo Umbauten etc. | Forum
ReDLineMKIV Driver
Sep 5 '11
-4AN Öl Zulauf Resrictor aus CNC gefräßtem Alu 12€
-10AN Öl Rücklauf aus CNC gefräßtem Alu 10€
Y Block Verteiler aus Alu mit 3/8NPT Anschlüsse und -6AN Fittings Eloxiert 25€
T3 divided twin scroll Krümmer/Turbo Dichtungen je 3€
-4AN straight und 90° Grad Fittings Alu hard anodized 7€ & 10€
-10AN 90° Grad Fittings Alu hard anodized 14€
EXTERNAL FUEL PUMP 044 0580 254 044 K-Jetronic Style 5bar 700-800HP (1:1 Bosch Nachbau, kein Orginal!) 75€
ReDLineMKIV Driver
Dez 6 '11
HKS Super SQV 4 Bov mit Zubehör- NEU 140€
HKS SSQV Weld ON Aluminium Flansch 25€
Autobahn88 Fuel Swirl Pot 4L Komplett Set mit 5meter Leitung&Fittings 170€
Type:
Aluminum Fuel Surge Tank Complete Kit 4 Liter x 1
Car:
Universal for Sport Cars
Color:
Silver - Aluminum Made
Application:
Drift Racing, Drag Racing, Street Racing and Track Day
Size:
4 Litre ( 4000 ml )
Dimension H26 x L13 x W13 (cm)
Specification:
The complete fuel system includes :
- 4 Litre Aluminum tank has 6 Ports for Twin Fuel Pumps Installation
- 6 x AN6 Fittings included
- 2 x Port Plugs included
- 4 x AN6 Straight Swivel Ends
- 4 x AN6 90Deg. Swivel Ends
- 2 x AN6 180Deg. Swivel Ends
- 5 Meter AN6 Stainless Mesh Fuel Hose
This is a complete fuel system / kit provided by autobahn88. No hassle to purchase fittings and hoses; the kit has all fittings included. The only thing is to buy suitable fuel pump thus the fuel system will be completed.
Fuel Surge Tanks manufactured by autobahn88. The need for a fuel surge tank comes about when the level in the main fuel tank is decreased to a point that under cornering, acceleration and inclines, the main fuel pickup is briefly uncovered. This is very detrimental to a fuel injected vehicle. The engine literally "runs out of gas" causing the engine to go lean and shut off. Carbureted applications are also affected, but not as quickly.
This is essential for Drift Racing, Drag Racing, Street Racing and Track Day
ReDLineMKIV Driver
Feb 5 '12
Jede Menge Anschlüsse für Turbo und Ölwanne( 4an Zulauf, Adapter für Ölwanne vom Turbo 10an, Dichtungen etc)
90° Elbows mit 3' und 2,5'
ReDLineMKIV Driver
Feb 6 '12
20meter - 10AN Stahlflexleitung von Autobahn88/Zenaracing 200€ (Einkaufspreis war 29usd pro 1,5meter ohne Versand)
Orginal 17 Zoll Toyota Supra Felgen 17x8,5J vorne und 17x9,5J hinten mit Sommerreifen(vorne neue Avons, hinten alte Dunlops) am besten Abholung oder Versand ohne Bereifung.
ReDLineMKIV Driver
Jan 28 '13
Wow alter Thread, aber die Teile sind noch zu haben :grinning:
Jan 28 '13
Bei den Original 17 Zoll Felgen steht kein Preis dabei..
ReDLineMKIV Driver
Jan 28 '13
kann ich leider nicht mehr editieren, 500€ für OEM Felgen und Reifen
1x HKS SSQV Weld ON Aluminium Flansch 25€ geht an Scarefaze (4 hab ich noch)
ReDLineMKIV Driver
Feb 15 '13
044 und 413 Bosch Triple Benzinpumpenhalterung 50€
in ein paar Wochen habe ich dann auch hier jede menge Teflonbeschichtete Stahlflexleitung von Autobahn88 in verschiedenen größen und auch dazugehörige Fittinge.
