wer besitzt dieses Gelb, das an hier Supra ist? | Forum
jazz
Sep 26 '06
hallo Kerle mein Namen Jazz im von Großbritannien, kann jemand erklären mir, der dieses gelbe Supra die Verbindung ist unten besitzt, liebe ich die Räder und ich wünsche das genaue die gleichen Räder, wie dieser Kerl diese Person könnte, oder jedermann die Maße und den Versatz der Räder kennt? und auch welche Räder sind sie? Dose jemand email ich die Informationen zu [EMAIL]jass897@hotmail.com[/EMAIL] oder P.M., die ich gefalle
www.mkiv.de/galleryshow_64.htm
BlueW
Sep 26 '06
Please write english.
we´ll understand you.
Wheels are "Folger Cup4"
front 10x19
rear 12.5x19
Peter10654
Sep 26 '06
Jazz
You can send me a PM about the UK Board if you like. Username is the same as here. "Peter10654" ! I bought the Supra from Dale "Skunk2"
Cheers
Peter
jazz
Sep 26 '06
what are the offsets on the yellow supra?
RZTwinturbo Driver
Sep 26 '06
VA: 10x19zoll 235/35 R19
HA:12,5x19zoll 315/25 R 19
Folger cup4
jazz
Sep 26 '06
thanks hopefully i will buy these and they would be fitted on my supra wth trial rear and do luck front and oem skirts
Sep 26 '06
The importer for these wheels is located a kilometer from my home, I might be able to get you a price if you want me to. If I ain't wrong, these wheels are made by Braid.
jazz
Sep 26 '06
i can get these wheels from a uk trader they are made by braid they used to be folger cup 4, anyways could you just double check that the ones on this black supra are correct offsets and measurements if they are then i will be ordering the same ones
www.mkiv.de/index.php?p=showtopic&toid=1756&area=1&high=
It is Exterminators Car. mkiv.de/benutzer/22.htm
just want to confirm these are the correct details of the wheels
Front: 19"x10 ET25,7 with Yokohama AVS Sport 235/35ZR19
Back: 19"x12,5 ET34,65 with Yokohama AVS Sport 315/25R19
Peter10654
Sep 26 '06
I never seen an offset with "comma"
You are sure thats the offset :blush:Mostly the offset are Numbers like 30 oder 35 ....
It is not possible to get the Offset from the yellow supra at the moment.
Peter
jazz
Sep 26 '06
i asked the uk wheel trader he said sounds right thats why i want to confirm them with the owner of these, anyways dont worry about the yellow ones i need to know about these ones on th eblack one just want someone to confirm they are right
jazz
Sep 27 '06
can someone please find out the number stamped on the black supra rim? please
