Zündkerzentest und Empfehlungen was habt ihr so ... | Forum
Feb 4 '07
Habe lange gesucht , was habt ihr so verbaut?
Normally Aspirated
NGK - Standard - BKR5ES-11 (2382) - gap 1.1mm
NGK - V-Power - BKR5EYA-11 (2526) - gap 1.1mm
NGK - G-Power Platinum - BKR5EGP (7090) - gap 1.1mm
NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm
NGK -OE Laser Iridium - IFR5T11 (4996) - gap 1.1mm
NGK - Iridium IX - BKR5EIX-11 (5464) - gap 1.1mm
Denso Platinum - PK16R11 - gap 1.1mm
Stock TT
NGK - BCPR6EP-11 - gap to 1.1mm PLATINUM
NGK - BKR6E (2756) - gap 1.1mm
NGK Iridium - BKR6EIX-11 (3764) leave gap alone
Denso Platinum - PK20R11 - gap 1.1mm
Denso Iridium - IK20 - leave gap alone
TT @ upto 1bar
NGK - BCPR7ES (3330) - gap 0.9mm
NGK - BKR7E (6097) - gap 0.9mm
NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone
Denso Platinum - PK20R11 - gap 0.8mm
Denso Iridium - IK22 - leave gap alone
TT/hybrids @ upto 1.3bar
NGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK24 - leave gap alone
Single Turbo/Big Twins @ upto 1.3bar
Single Turbo/Big Twins @ upto 1.8bar
NGK - BCPR8ES - gap 0.6-0.7mm
NGK - BKR8E - gap 0.6-0.7mm
Denso Iridium - IK27 - leave gap alone
Single Turbo/Big Twins @ 2+bar
NGK - BCPR8ES - gap 0.6mm ??? UNTESTED
NGK - BKR8E - gap 0.6mm ??? UNTESTED
NGK Iridium - BKR8EIX or BKR9EIX? - leave gap alone ??? UNTESTED
Denso Iridium - IK27 to IK31 - leave gap alone ??? UNTESTED
Feb 4 '07
Erst hatte ich NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm 1000 KM gefahren
dan gewechselt auf :
NGK Iridium - BKR7EIX gap 0.7mm
Die NGK -Laser Platinum - BKR5EP-11 ( 3440) -gap 1.1mm Habe ich noch.
Wen Jemanden sie haben will, Preiss per PN.
SpeedUp Driver
Feb 4 '07
Bin sehr zufrieden damit.
Feb 4 '07
Hi Speedup,
einfach eingebaut oder noch den Abstand verändert? Ich schraube meine auch gerade rein. Habe seit Gestern doch etwas viele Fehlzündungen bei Volllast. Nun kommen mal die Denso IK 24 rein und die IK 20(waren auf die AEM eingestellt)in den Müll. Die IK 20 sehen nach 30TKM aber noch gut aus. Ich muß wieder raus, alles wieder zusammenbauen.
Feb 4 '07
IK 24 ist drin und alle Zündungstörungen sind weg.
Peter10654
Feb 4 '07
Habe auch Denso IK24 auf normalem Gap. Kein Unterschied zwischen normalem Gap und 0,7er gemerkt.
Fahre aber mit Zünkraftverstärker HKS DLI... Das wäre vielleicht auch noch zu bemerken und 1.2 bar Druck auf dem Single.
DerKrieger Driver
Feb 4 '07
Denso IK24 die besten Kerzen die ich bis jetzt hatte. Hab das Spaltmaß vor dem einbau gemessen und musste nichts verändern.
Falls noch jemand Denso IK24 Kerzen braucht kann er sich bei mir melden.
cu Andy
Fusi Driver
Feb 5 '07
Hatte im Nissan auch Denso und war sehr zufrieden damit.
Sehr günstig bekommt man sie hier: www.kettenmax.de
DerKrieger Driver
Feb 5 '07
naja,
wie gesagt bei Interesse bei mir melden.
cu Andy
eXplorer Driver
Feb 6 '07
Zuerst NGK 6097 an und bei LD über 1,25 hin und wieder Zündprobleme ..
Jetzt Denso IK 24 und keine Probleme mehr! :blush:
Emotion-Cars
Feb 27 '07
Denso Iridium VK16 in meinem Jap. ModelL ( non Turbo ca 295PS) und die halten ca 20-30 TKM bei meiner anderen müsste ich mal schauen. Habe aber mit beiden keine probleme .
Feb 27 '07
Ich hab Denso Iridum IK 27 und ich hab auch das gap alone geleaved :grinning:
Mär 12 '07
Fahre die NGK BCP 7 EVX Platin 050-055mm
bis 1.8 Bar mit oder ohne Zündverstärker kein Problem
mfg thomas
eddie Insider
Mär 26 '07
richtig sooooo! ich sag ganze zeit, es geht mehr mit nem single und normalsprit, wie die meist prfezeiten 1,2 bar in de´n staaten.....
Mär 26 '07
mfg,
Okt 22 '08
Normally Aspirated
Stock TT
TT @ upto 1bar
Habe wieder mal das alte Thread ausgegraben weil ich mir immer noch unsicher bin wegen meine Zündkerzen.. :rolleyes:
Meine frage ist :
Die NGK Iridium - BKR7EIX - Kerzen.. Sind die gut für Single Turbo bis 1,8 Bar ? Oder nur die: NGK - BKR7E (6097) - ?
Ich habe die BKR7EIX und deshalb unsicher weil ich immer noch nicht verstehe was die letzten Buchstaben IX Bedeuten ???
Danke !
Lg
Okt 25 '08
Kann mir keiner weiterhelfen mit dem Kerzen ? :schlecht:
wert Driver
Okt 25 '08
Ich hatte gestern richtige probleme(fehlzuendungen der wagen spuckte nur noch).Habe die Ngk laser platinum drinn.Jetzt warte ich auf die Denso ik24.Muss man beim einbau etwas beachten oder veraendern?
Okt 25 '08
Na Klar Tomi
BKR7EIX
B=M14 gewinde
K=16er Schlüselweite
R=Endstört
7=wärmewert
E=Gewindelänge
IX=Iridium
Ich verwende die PFR7B
P=Platinium Elecktrode
F=M14X19 gewinde mit 16er SW
7=wärmewert
Steff Driver
Okt 26 '08
Hi Tomi
Hatte als erstes die BKR6EIX drinne da sind mir aber zwei Stück geschmolzen
da nach bin ich auf Denso IK24 umgestigen und war bestens zufrieden.
Nach der Motorrevision wollte ich auch wieder die Denso aber da die nicht schnell lieferbar sind und ich sie nicht bei meinen Händler bekomme, habe ich es mit den BKR8EIX probiert und kann nur sagen das ich damit auch zufrieden bin die sind optisch baugleich mit den ´Denso haben nur gleich einen gap von 0,6.
Da du aber ja richtig Druck fahren willst würde ich auch diese nehmen da sind deine inneren Temparaturen ja auch noch ein bisschen höher und meines erachten sind die 7er noch zu heiß.
Dann kommt noch dazu das deine AEM ja auch noch abstimmen musst und es schnell passieren kann das dein Motor mal kurzfristig abmagert da würde ich auch kein Risiko eingehen.
