Differenzialöl | Forum
MikzuIV Driver
MikzuIV Jun 21 '06
Hi.
What is the best oil for the rear diff? The one with torsen lsd.
I changed it the last summer and there was some green budding inside it, and a bit of steel flakes on the magnet plug :grinning:
So I changed it to some normal diff oil.
It was a pain to get the oil inside. I put a hose from the diff to the oil can, and put the can under the wheel while the car was lifted, and then slowly lowered the car.
MacGyver style :grinning:I really need to buy an oil pump :blush:
Pentti.
udo
udo Jun 22 '06
hi, i think the best you can use is the original diff oil from toyota.
cu udo
