    Gewichte | Forum
    Aufgrund einer Anfrage stelle ich hier mir mal eine Liste
    mit Gewichtsangaben zu einzelnen Komponenten ein:
    Teil.....Gewicht in lbs....Gewicht in kg
    Abschleppöse hinten (body - rear tow hook) 1,000 0,450
    Abschleppöse vorne inkl. 2 Schrauben (body - front tow hook) 5,000 2,250
    Airbags, beide (sensor module and steering wheel) 10,500 4,725
    Aktivkohlefilter (charcoal canister / with nuts and lines) 2,500 1,125
    Antenne elektrisch 0,000
    Auspuff (exhaust - cats / pre-cat - 10 lbs, cat - 19 lbs) 29,000 13,050
    Auspuff (Stock Exhaust / only Piping and Muffler) 0,000
    Auspuff IDOL 0,000
    battery - Die Hard 100 month 37,000 16,650
    battery - Optima Blue Top Marine 40,000 18,000
    blow off valve - HKS Super Sequential (SSQ BOV) 0,900 0,405
    brake - front caliper with pad (16 * 2) 32,000 14,400
    cam shaft (intake) 7,660 3,447
    cover - fuel tank (under car) 6,750 3,038
    drivetrain - differential (6spd) 120,000 54,000
    drivetrain - differential (auto) 92,000 41,400
    drivetrain - drive shaft (auto) 18,000 8,100
    drivetrain - tranny - 6spd 120,000 54,000
    drivetrain - tranny - automatic 0,000
    drivetrain - tranny - SP built automatic 128,000 57,600
    drivetrain - tranny - torque converter 40,000 18,000
    ECU - fuel 4,000 1,800
    engine - head (including cams, caps and cap bolts. w/o cam gears or studs) 67,000 30,150
    engine - short block 230,000 103,500
    exhaust - Boostlogic downpipe (silver coating) 0,000 0,000
    exhaust - Boostlogic midpipe (silver coating) 0,000 0,000
    exhaust - catback 0,000
    exhaust - catback - A'PEXi N1 33,000 14,850
    exhaust - catback - Greddy Power Extreme 38,000 17,100
    exhaust - catback - Greddy Street Performance 45,000 20,250
    exhaust - catback - HKS Carbon / Ti (95mm, 3.75":wink: 0,000 0,000
    exhaust - catback - Veilside titanium 10,000 4,500
    exhaust - hks frontpipe 5,000 2,250
    exhaust - rmm dp 0,000
    floor mat (front - 2 * 2) 4,000 1,800
    floor mat (rear - 1 * 2) 2,000 0,900
    front strut tower brace - Cusco (aluminum) 5,000 2,250
    front strut tower brace - Cusco (carbon fiber) 4,000 1,800
    front strut tower brace - TRD 9,000 4,050
    headlight (plastic U.S. w/o bulbs - 6 * 2) 12,000 5,400
    Karosserie Heckklappe komplett mit allen Teilen, (hatch) 61,000 27,450
    Karosserie Heckklappe nur Blech, hatch (structure - 33lbs) 33,000 14,850
    Karosserie Heckklappe nur Heckscheibe 26,000 11,700
    Karosserie Heckklappe nur Zubehör, hatch (electronics, and two shocks - lbs) 2,000 0,900
    Karosserie Kofferraum (trunk - jack w/ handle) 5,000 2,250
    Karosserie Kofferraum (trunk - spare tire) 35,000 15,750
    Karosserie Kofferraum (trunk - styrofoam / both pieces) 1,000 0,450
    Karosserie Kotflügel (fender) 9,000 4,050
    Karosserie Kotflügelabdeckung (body - fenderwell undercovers) 2,000 0,900
    Karosserie Motorhaube mit Verschluss (hood with liner and front latch) 28,000 12,600
    Klimaanlage A/C Kompressor (Compressor) 0,000
    Klimaanlage A/C Kondensator und Tank (A/C condenser and tank) 8,000 3,600
    Kühler - Fluidyne 20,000 9,000
    Kühler (radiator w/shroud) 25,000 11,250
    LLK FMIC (intercooler - HKS Type S core) 11,460 5,157
    LLK FMIC (intercooler - HKS Type S piping) 10,040 4,518
    LLK original (intercooler - stock core) 4,000
    Nockenwellenräder cam gear - Jun Cam Gears 0,000
    Nockenwellenräder cam gear - Unorthodox 0,740 0,333
    Nockenwellenräder original (cam gear) 0,960 0,432
    Querbeschleunigungssensor inkl. Halterung und Stecker 0,000
    Räder tt wheels (93-97) - front (w/o tires) 24,750 11,138
    Räder tt wheels (93-97) - rear (w/o tires) 26,550 11,948
    Räder tt wheels (9:sunglasses: - front (w/o tires) 0,000 0,000
    Räder tt wheels (9:sunglasses: - rear (w/o tires) 0,000 0,000
    Riemenscheibe pulley - alternator 0,500 0,225
    Riemenscheibe pulley - crankshaft 0,000 0,000
    Riemenscheibe pulley - power steering 0,000 0,000
    Riemenscheibe pulley - Unorthodox alternator 0,200 0,090
    Riemenscheibe pulley - Unorthodox crankshaft 0,840 0,378
    Riemenscheibe pulley - Unorthodox power steering 0,800 0,360
    Riemenscheibe pulley - Unorthodox waterpump 0,500 0,225
    Riemenscheibe pulley - waterpump 1,000 0,450
    Seitenversteifungen Front 0,000
    Sitz Beifahrer (seat - TT passenger) 34,000 15,300
    Sitz Fahrer (seat - TT driver) 54,000 24,300
    Sitz Rückbank oben (seat - upper back with bolts) 20,000 9,000
    Sitz Rückbank unten (seat - lower back) 0,000
    Stereo Lautsprecher und Türboxen (subwoofer and box) 8,500 3,825
    Stereo Radio-/CD-Einheit (head unit) 5,000 2,250
    Stereo Verstärker (amplifier) 5,000 2,250
    Stoßstange hinten (bumper - rear - including .5 lbs bolts) 17,500 7,875
    Stoßstange vorne (bumper - front, aluminum) 4,000 1,800
    suspension - Eibach springs & KYB shocks (17lbs * 4) 68,000 30,600
    suspension - front sway bar 8,000 3,600
    suspension - HKS Hyper Dampener II (12lbs * 4) 48,000 21,600
    suspension - rear sway bar 3,000 1,350
    suspension - shock & spring 0,000
    suspension - Stillen front sway bar 12,000 5,400
    suspension - Stillen rear sway bar 3,000 1,350
    suspension - Tein CS coilovers (12.25lbs * 4) 49,000 22,050
    suspension - Tein FLEX coilovers (14.25lbs * 4) 57,000 25,650
    suspension - Tein HA coilovers (18lbs * 4) 72,000 32,400
    suspension - Tein RA coilovers (14.5lbs * 4) 58,000 26,100
    suspension - Tein RE coilovers (13.75lbs * 4) 55,000 24,750
    suspension - TRD front sway bar (23 percent stiffer) 0,000 0,000
    suspension - TRD rear sway bar (23 percent stiffer) 0,000 0,000
    Karosserie Tür / Seitenaufprallschutz (door - inside crash safety bar) 3,250 1,463
    Turbo single - cast manifold 0,000
    Turbo single - Greddy T78 (complete kit w/ Blitz SS midpipe) 75,000 33,750
    Turbo single - header - Boostlogic (black coating) 0,000 0,000
    Turbo single - header - hks 16,000 7,200
    Turbo single - header - rps 0,000
    Turbo single - wastegate - HKS GT (60mm) 5,000 2,250
    Turbo single - wastegate - HKS Racing (50mm) 0,000 0,000
    Turbo stock twin (complete assembly including rmm dp, no maf, or airbox) 105,000 47,250
    Türinnenverkleidung 1,000
    twins - turbo assembly minus the collector right before the dp 56,000 25,200
    Ventildeckelabdeckung 0,500
    wing (rear spoiler) 6,000 2,700
    Hier einige Teile, die ich einzeln gewogen habe:
    Teil ...... Gewicht in kg
    ABS/TRC-ECU mit Halterung 0,832
    ABS-TRC Relaiskasten 0,354
    CruiseControl-ECU 0,216
    CruiseControl-Motor mit Seilzug 1,400
    Diebstahl ECU 0,122
    el. Antenne 1,000
    Fensterheberschalter links 0,142
    Fensterheberschalter rechts 0,056
    Heckscheibenwischer mit Motor und ECU 1,330
    Heizung Heckscheibe mit Kabelbaum 0,426
    Heizung komplett ca. 5,000
    Heizung Lüftermotor 1,330
    Heizung Servomotor 1- 0,198
    Heizung Servomotor 2- 0,188
    Heizung Servomotor 3- 0,178
    Hilfs-/Stabilitätsbleche 2x (Fahrgastzelle) inkl. Befestigungsschrauben 1,204
    Hilfs-/Stabilitätsbleche 2x (Fahrgastzelle) inkl. Befestigungsschrauben 1,624
    Hilfs-/Stabilitätsbleche 2x (Fahrgastzelle) inkl. Befestigungsschrauben 1,342
    Hilfsbleche 2x (Halterung wofür?) 0,260
    Kabel, Stecker, Relais, Kleinteile 5,000
    Klima ECU inkl. Ca. 15 cm Kabel 0,466
    Klimaanlage Steuereinheit (Regler/Knöpfe) 0,394
    Lampenausfallsensor 0,040
    Notrad 17,00
    Querbeschleunigungssensor inkl. Halterung und Stecker 0,122
    stereo - amp 2,500
    stereo - head unit 2,500
    Türöffner links 0,112
    Türöffner rechts 0,112
    two airbags, sensor module and steering wheel 5,250
    Uhr mit 10 cm Kabel dran 0,092 [/B]
    Seiten: 1 2 3 »
