    Chaser - mit Suprateilen ;) | Forum
    TheThistle
    Die Beschreibung nehm ich einfach mal aus den Verkaufsbeschrieb, den ich vor zwei Tagen geschrieben habe :wink:
    Engine / Injection / Exhaust
    Modified 1JZ VVTi Head with HKS 264° camshaft
    SARD Fuel Rail (2x In 1x Out)
    820cc Injectors
    Custom intake Manifold
    Forged Pistons
    H beam conrods
    Blitz Top Mount Manifold T4
    Garrett GTX3582R 0.82 A/R
    Big Wastegate
    3.5 Inch custom Downpipe with AEM lambda sensor, and original lambda sensor
    3.5 Inch custom Exhaust pipe
    Xforce Varex Muffler, or straight pipe
    56 Liter (15 Gallon) Fuel Tank in trunk
    4 Liter Swirl Tank
    3x Bosch 044 Fuel Pump, each with a Filter!
    Dash10 Fuel Line (split to 2x Dash 8 at the Fuel Rail)
    Oil Filter relocation with Thermostat
    Big Autobahn88 Aluminium Radiator
    Two very strong Spal Radiator fans
    2 big Autobahn88 Oil Coolers with two 4 Inch power fans
    (No temperature problems!!)
    Drivetrain:
    OS Giken 4 Plate Clutch (3 Plate rated to 1200hp, 4 Plate not rated )
    R154 Transmission
    Shortshifter
    TRD 1.5 Way Limited Slip Differential
    4.11 Diff Ratio
    Chassis / Suspension:
    1997 Toyota Chaser JZX100 Tourer V, Automatic Chassis with 116'000km
    Tein Superdrift Suspension, custom setup (D1 spec)
    Ikeya Formula, Cusco and other adjustable arms
    Bigger anti roll Bars
    FRP Bonnet with quick release
    6 pot Project Mu front calipers and rotors
    2 pot rear calipers with project mu rotors
    Stainless steel brake lines
    10 wheels - 4x 10x18, 6x 10x17, offset 12
    Koguchi carbon wing
    Dream Factory fender flares (professional cutted fenders and professional welded at the rear fenders)
    Interieur:
    Cusco Safety 21 Rollcage
    Sparco Driver Seat (FIA Certified)
    Cobra Passanger Seat (Fia Certified)
    FIA Certified Belts
    Batterie in a Box (FIA) behind passenger seat
    Batterie quick release connectors
    Sparco 350mm Steering Wheel
    Gauges (Water Temp, Oil Temp, Oil Press, EGT, Boost)
    AEM Air/Fuel
    Carbon Shift Knob
    And so on
    Ist einiges gemacht an dem Wagen :wink: fährt sich ganz gut soweit. Was mich etwas stört ist die recht "weiche" Lenkung, wie man es von Toyota (leider) gewohnt ist.
    https://scontent-b-ams.xx.fbcdn.net/hphotos-xpf1/t1.0-9/10464167_333512843463325_2620208374332520380_n.jpg
    https://scontent-a-ams.xx.fbcdn.net/hphotos-xpf1/t31.0-8/10557064_10204304230916878_4321408500219930243_o.jpg
    https://scontent-b-ams.xx.fbcdn.net/hphotos-xfp1/t31.0-8/10497874_839648919419303_193549761348613352_o.jpg
    https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xpf1/t1.0-9/995035_10204306952104906_9082217435173726080_n.jpg
    https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfa1/t31.0-8/10560395_10204306956145007_4348923792764104046_o.jpg
    https://scontent-a-ams.xx.fbcdn.net/hphotos-xpa1/t1.0-9/10351750_10204306953144932_7485503767582654983_n.jpg
