German spec audio | Forum
ossar
ossar Okt 1 '12
Hello fellow supra lovers,
Wondering if the german spec mk4 supra ever came with the 7-speaker system and how do I know if mine did?
Japanfanatic Okt 1 '12
No it didn't. Only US-Spec and some J-Spec versions came equipped with the subwoofer.
KingSchnitte DrIvEr
KingSchnitte Okt 1 '12
Just look under the passenger seat. Thats the place where normaly the stock ampfiler is located. If there is any wiring harness, check if that is speaker cable and check your trunk for mounting holes for the woofer.
:grinning:
ossar
ossar Okt 2 '12
Thanks, too bad. I thought the euro versions got equipped with everything possible.
Do you know what stereos were available, cd changer etc? Part numbers?
:grinning:
No amp there, there is a wiring harness but only one connector. I have the oem amp so I'm missing a harness, part number 82166-14100
